where to mount probe for fan switch???
Old May 3, 2007 | 12:54 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
ok i read throuh this thread--https://www.thirdgen.org/forums/cool...ghlight=hayden --and the instructions that came with the switch, i have hayden 3652. i ops checked it and it failed. according to the instructions it said to make sure the probe is touching a tube. also said to put it 3-4 inches below the inlet hose.
my 2 questions--
1. the inlet hose is on the upper drivers side correct?
2. where are the tubes at in the radiator?
thanks for all the help.
Old May 3, 2007 | 10:38 AM
JustinSane's Avatar
Re: where to mount probe for fan switch???
the tubes are between all those little foil like zig zags, push the sensor threw the radiator carefully a few inches from the top inlet on the rad and secure it so its tight.
Old May 3, 2007 | 11:31 AM
yeah but where exatcly is the tude at? i want to put the probe right next to one if i can
Old May 3, 2007 | 12:36 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
The tubes are the flat little lines you see in between all the zig zag foils like "JustinSane" mentioned above. Just push it through about 2-3 inches below the inlet hose and secure it and you're good to go. I've got the same kit on mine. Works fine. If you've op checked it and it doesnt work more than likely it is wiring.
Old May 3, 2007 | 12:53 PM
when you installed yours did you use the relay it came with? if so what did you do with the old relay?
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Jae992
Aug 27, 2015 09:07 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
TA8487
Aug 16, 2015 12:21 PM
