Heater Hose Connection?
Old Apr 30, 2007 | 09:50 PM
MG66Biscayne's Avatar
Car: 1984 Z28
Engine: L69
Hello, I'm new to third gens. Is the heater hose supposed to connect to the radiator rather than the water pump? The radiator on my recently acquired 84 Z28 has what appears to be a heater hose outlet on the radiator tank below the filler neck. The previous owner plugged it with a short length of hose. The hoses are now connected to the manifold and a replacement water pump like every other small block I have had. Just wondering what the correct hose routing should be.
Thanks,
Mike
Old May 2, 2007 | 09:08 PM
99transamgirl's Avatar
Car: 84, 99 Trans Am
Engine: 305 G, LS1
Re: Heater Hose Connection?
don't know if i'll be much help but i'll try. I can't think how my 84 is set up since it's been dead for a while but I can describe my 82. below my fill cap I have a thin hose that runs to the overfill tank. then below that hose is a spot is another location for a hose. on mine it has a rubber cap/hose that has a clamp on it. don't know if this is for draining or what. it's just blocked off. below it is a metal line running out of the radiator and on the very bottom a large hose going to the water pump. this is all top to bottom from my fill cap. maybe i've help. I hope
Old May 2, 2007 | 09:38 PM
j dezzy's Avatar
Car: 87 TA
I've never seen...or even heard of the heater hoses being hooked to the radiator. water pump and manifold is all I know of for a small block.
Old May 2, 2007 | 09:56 PM
Engine: 305 G, LS1
my fault. I don't know what I was thinking. the heater hoses to the core is what your asking. the black one( if your's is black. the thinner hose) goes into the manifold and the orange( if yours is this color.the thicker hose) goes to the top or side of the water pump. sorry for the confusion. I'm not thinking very clearly.
Old May 2, 2007 | 10:44 PM
iroc88lb9's Avatar
technically....it can go either way.
on the older setups,the flow line caem from the water pump,into the heatercore,then out to the intake manifold
on the newer setups,depending on tbi or TPI....it goes from the intake manifold,into the throttle body,out of the throttle body,then into the heatercore,and the return line dumps into the radiator,just under the filler neck.
personally...id route it like the newer setups...less clutter,and no hoses laying across your valve covers.
Old May 3, 2007 | 12:00 PM
Car: 1984 Z28
Engine: L69
Thanks for the responses. My setup is exactly how KITT84 described. Nice to hear, IROClb9, that the return line can go either to the intake or the radiator tank. I much prefer the uncluttered look as shown in your picture. I'm just starting to work on my carbureted 84 Z and can't believe how many hoses etc. I have to work around to change the valve cover gaskets.
Thanks again,
Mike
Old May 3, 2007 | 01:08 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
radiator hookup is super common
the radiator i got from an 89 for mny 82 is heater hose to the radiator
the water pump port gets blocked off with a pipe plug
alot of the trucks are like this, as well
at least half of them, especially with HD cooling system option and also the larger engine options too such as the 400 and 454, etc
its the 3/4" hose that gets connected to either the rad or the w/p
the 5/8" is always on the intake regardless
good luck
Old May 3, 2007 | 03:51 PM
Car: 1984 Z28
Engine: L69
Thanks Randy, good information. It's an L69 motor that I'm just beginning to get into (routine tune up, maintenance etc.). I'll be posting more questions soon as I start delving into the pollution hook ups and carb adjustments.
Mike
racereese
Oct 10, 2015 09:39 PM
Formula8r89
Sep 22, 2015 04:24 PM
Stryker412
Sep 20, 2015 06:59 PM
gta892000
Sep 16, 2015 12:37 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
