air bubbles in coolent tank?
Old May 5, 2007 | 09:26 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i just drained my radiator to put in a new coolent temp sensor and cold start switch.
i refilled my radiator and jug with coolent.
i started the engine. i noticed air bubbles coming up into the coolent jug from the hose that feeds the radiator.
any ideas?
Old May 6, 2007 | 12:13 AM
dingle's Avatar
Car: '83 Camaro
Re: air bubbles in coolent tank?
any ideas?
It takes a while to get all the air bubbles out. :shrug: As long as there are no leaks I wouldn't worry about it unless it is still happening after a few days of driving.
Old May 6, 2007 | 12:16 AM
brad_26's Avatar
Car: 1984 camaro
Engine: 2.8l to 383 stroker
Transmission: t5 to th400
Axle/Gears: 12 bolt soon with 3.73s
you should bleed the system
Old May 6, 2007 | 12:38 AM
Bobby_80s's Avatar
Axle/Gears: no idea
how do you bleed the system?
Old May 6, 2007 | 01:54 PM
dingle's Avatar
Car: '83 Camaro
I thought the coolant system would get all the air bubbles out itself you just keep topping the radiator off. :hmm:
Old May 6, 2007 | 02:05 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
To bleed the system you should stick a funnel in the neck of the radiator where you fill it, pour coolant into the radiator until it is full and then pour some more in so that it is almost full in the funnel also. Then start the car and you will see the air bubbles coming out. Continue filling it up until all the air bubbles come out and until your coolant level is correct.
1992 Trans Am
May 10, 2023 07:19 PM
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
theurge
Aug 21, 2015 12:46 PM
