Car is overheating and I don't know why
Old May 10, 2007 | 08:27 AM
Z28_1991_Camaro's Avatar
Car: 1991 z28
Engine: 5.7L
I have a 91 Z28 tpi, I recently swapped my 305 with a rebuilt 350. To the best of my knowledge I replaced every sensor durning the swap. Ive been driving it for a few months now, it idles poorly but i never had any other issues with it until about a week ago it started overheating. I can drive about 5-10 mins before Im hitting the red on the temp gauge.
I noticed one of my cooling fans was not turning on so I replaced the motor only to find that didnt fix the problem. I temporarily put a switch on the one fan now so it stays on all the time and the other fan goes on whenever.
I aslo replaced my thermostat and it had no affect on how hot the car ran.
What would cause the fan to stop working and why is my car over heating?
Also, I rememeber when I used to turn my key forward in the ignition without actually starting the car I could hear my fans turn on but now they dont do that, I cant remember when it stopped doing that though. What controls that? Is it a sensor or the computer or something else?
Old May 10, 2007 | 08:15 PM
91 355 z28's Avatar
Re: Car is overheating and I don't know why
well your fan not working is 9 out of ten times a relay or ect (engine coolant temp sensor) but as long as the fan is on it shouldnt over heat.. i would check the coolant level, make sure ur thermostat is working, on the bottom (copper color is the temp it opens at, should be 195, or 180.. boil some water with a thermometer in the pot and using some tongs or somethin hold the stat in the pot it should open at specified temp.. other then that try a flush.. something may be clogged.. maybe water pump took a ****, impeller shaft broken? unlikely but i guess possible if it rusted
Old May 11, 2007 | 08:39 AM
Car: 1991 z28
Engine: 5.7L
I took the thermostat out completely and the running temperature seems to have stabilized. I think it's odd that I had overheating issues with my old thermostat which is only a few months old and the brand new one I just put in.
Why don't my fans turn on anymore when I turn the key forward in the ignition without actually starting my car?
Old May 11, 2007 | 12:04 PM
ACKRN07's Avatar
I have an 84 Autoform Z28 Camaro. It seems to run hot all the time. It doesn't actually overheat but if I am in traffic, I think I can actually feel some hot air coming from the ducts. I don't have a dual fan setup. The thermostat is brand new. I have heard that the 3rd gen design is known for not allowing enough air flow under the nose to get to the engine??
Anyone have similiar problems? Do you think a dual fan set up with maybe a dashboard switch would sovle my problem when I'm in traffic??
I have also noticed that the car starts great "cold". But after running, parking and then re-starting a hot engine, it hesitates. A timing problem perhaps??(my car is 5 speed manual transmission)...thanks in advance for any help/suggestions.
Old May 11, 2007 | 11:54 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Out of both of my 3rd gens (88 & 92) neither of them have had an overheating issue because of not enough air getting to the engine. So long as you keep that black plastic air damn on under the car, the design is fine.
Bad thermostats are not uncommon. At least not to me. I went through several in my 88 and then I said to hell with it.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyleb24
Aug 15, 2015 08:24 AM
