oil cooler location?
Old May 15, 2007 | 11:45 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
right now its on the front of the radiator (single fan) in the center, I think this is obstructing air flow. Anyone know where the factory location is or where i should mount it?
Old May 15, 2007 | 11:51 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil cooler location?
The factory never used an auxiliary oil cooler.
Old May 15, 2007 | 11:57 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
What your thinking about is the AC Condenser...in front of the radiator....which yes obstructs air flow. As for the oil cooler. Get rid of your AC and you'll have a big open spot in front of the radiator to put it.
Old May 17, 2007 | 11:47 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Sorry I didnt clarify, the TRANS COOLER is touching the condenser, and its transfering heat, I was wondering where else to mount it. Im gonna put in a condenser fan, or get a dual fan from an iroc, the condenser is getting to hot and its killing the compressor.
Old May 17, 2007 | 12:04 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
So you DO plan to keep your AC....then mount the cooler either inside your bumper behind the parking lamps or right under the radiator...under the car.
I dont have a condenser on my car so I am putting my cooler in front of the radiator and space it away a little (I am removing my fog lights)...I hate them anyway.
I plan to buy Griffins Radiator without a tranny cooler and buy my flex-a-lite kit and hook it up...thats not until next winter sooo.
P.S. You dont need dual fans unless your running that car in hot laps...I have a single with upgraded Stewart stage 2 pump, moroso 21lb radiator cap (cooling system must be pressure tested to 21 lbs before cap installation), 180 stat and soon my griffin radiator....basically a setup like this wont even need 1 fan...unless I run it hard...then even after I turn that fan on it wont ever go over 200 anymore.....guarenteed....at least mine didnt.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
