Replacement of cooling system, need part numbers
Old May 21, 2007 | 12:31 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
I'm replacing my entire cooling system, from the heatercore down to all the hoses. Most of the hoses are old and ready to collapse/pop any day, the rad has tons of bent fins and is too gunked up to even be cleaned. Water pump also failed, so the whole system needs to be switched out. I'm collecting part numbers on hoses, mostly, and perhaps this thread can help some other folks. The reason I'm asking for the part numbers for hoses is because the previous owner did a hack job on the current ones, so if I take a hose off, it's two or three sections with couplers and T-lines, not a full hose, and we can never figure out exactly what it is.
All part numbers are PartsAmerica(.com) numbers. I'm mostly including them in case someone spots a wrong part or knows of a better one. The goal is to get back to at least OE spec without spending a fortune(the car is unmodded as far as engine goes). There's also a few that I'm not sure what they are and I'm trying to price out the cost before I go and buy everything; plus, I want to have everything at once, so the gunk inside an old part isn't getting inside a new one.
-- Hoses --
2x Heatercore to metal pipe - ???
The three hoses coming off the heater control valve - ???
Bypass - Goodyear M63126
Upper radiator - Goodyear L61454
Lower radiator - Goodyear L61330
Radiator-to-overflow tank -- ???
-- Parts --
Radiator - Ready-Rad #433919
Water pump - Cardone #58327
Heater core - Ready-Aire #399083
Heater control valve - Factor Air #74805
Thermostat - Stant #13349
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
