What fans is everybody running??
Old May 30, 2007 | 09:22 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
The reason i ask is my stock fans are not cutting it. I'm running a procharger so space is limited. I was looking at the flexalite thin ones that flow 2500cfm... I would like to run the derale ones that flow 4000 cfm. Any feedback?? What do the stock ones flow?? THANKS!!
Old May 31, 2007 | 04:34 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: What fans is everybody running??
Im running a stock dual fan set up for my 383. I dont have a procharger, but it keeps my 383 at 180*.
Old May 31, 2007 | 05:45 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Im running the stock dual electric fans, however i only have a stock 305 tpi.
Old May 31, 2007 | 06:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
im going to be running a perma-cool fan in a pusher setup, single fan that pushes 3000cfm, i hope it works
Old May 31, 2007 | 10:26 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I'm running a dual 11" Spal fan setup. They pull 2780cfm and with a Griffin 1.25" tube radiator, it cools just fine.
http://www.slickcar.com/pdfs/11Fans.pdf
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
