constant fan running?
Old 06-22-2007, 10:43 AM
rebel1222's Avatar
Car: Looking
Could someone please explain how to wire my electric fane to a switch in the car so I can run it continually during the summer? I order the lower temp coolant relay switch from Hawks, and it runs just as hot as it did before.
I searched the previous posts to no avail.
Thanks ,
Kevin
Old 06-22-2007, 11:23 AM
johnsonm's Avatar
Car: 86 Firebird
Engine: LG4 feedback controlled 350
Transmission: used to be T5 now T56
Re: constant fan running?
If I recall correctly,
Find the fan switch (mine is in the head on the passenger side) splice the single wire coming from it. Do not cut it. Run the spliced wire and another wire hooked to a ground into the cabin. Place a switch between them and ground one end.
The switch closes the circut when it gets hot. By adding a splice with a ground you can flip it on when you want, but it will still come on automatically.
http://www.gmtips.com/3rd-degree/dox/tips/cool/cool.htm
This link has lots of good info, better than what I just told you. Have you read it?
this too
https://www.thirdgen.org/forums/cool...ght=fan+switch
RazorN8
01-07-2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
03-27-2016 04:05 PM
jbd1969
08-17-2015 07:06 PM
TA8487
08-16-2015 12:21 PM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: constant fan running?
