Fan trouble runing out of Ideas
Old Jun 23, 2007 | 04:50 AM
ReverendZ28's Avatar
Car: 1988 Z28
Engine: 350ci
Axle/Gears: Stock
I keep having problems with the fan... its a 305 tbi '88 with a single fan. The fan seems to come on when ever it feels like it. When i got the car I thought the fan was rigged to run direct. When I keyed the ignition to the on position the fan would come one. Well I pulled the relay and it was melted. So i replaced it and then it would not start. So I changed the passenger side temp switch for the fan. Was perfect for the first time then i would not kick bank on. Now it seems the relay is locked in the on position just like when I got it. So I tried to tap the relay with a screwdriver. Nothing then after about 20 min of driving the fan turns off and wont kick back on. Anyone have any idea where to look next?? The car nly over heats after the 20 min at stops and when going up hill air dam is in place. Any ideas Apreciate it everyone...-RevZ28
Old Jun 23, 2007 | 01:58 PM
xbcrguy182x's Avatar
Re: Fan trouble runing out of Ideas
Did you change your fan motor?
Old Jun 23, 2007 | 04:53 PM
Car: 1988 Z28
Engine: 350ci
Axle/Gears: Stock
Yea, changed evertyhing but the actuall wiring and the ecm so what does anyone think lol im runin out of ideas...-RevZ28
Old Jun 24, 2007 | 04:54 PM
Hoq do you know its overheating? Do you have a aftermarket gauge installed? Wat temp does it hit?
Old Jun 25, 2007 | 08:57 PM
Car: 1988 Z28
Engine: 350ci
Axle/Gears: Stock
I have the stock gague and aftermarket gauge installed and it runs to about 240-230 when up hill but as far as i can tell with everything installed it shouldnt be anywhere near that temp...
Old Jun 27, 2007 | 03:33 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i just wired my dual fans to a toggle inside the cab. in order to check your wiring i would start with that fan switch you have on the pass side. with the car off clip a test wire to the pass side switch wire and then ground it. turn on car. if the fan comes on the it could be that switch you have.
RazorN8
Jan 7, 2022 11:44 AM
krisner89
Oct 10, 2015 06:03 AM
utfan01ss
Sep 28, 2015 12:17 PM
Papaginos
Sep 27, 2015 03:29 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
