87 camaro heater control valve delete
Old Jun 24, 2007 | 11:49 AM
aretha's Avatar
Hi can some one help me with deleting my heater control valve cuz it broke to day.How do i hook the pipes up to bypass it and will it effect my engine cooling in any way I have got rid of my a/c and also done the throttle bypass thing my ride is a 1987 iroc-z camaro 5.7 tpi auto i look foreward to any reply thanx.
Old Jun 25, 2007 | 03:29 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
Re: 87 camaro heater control valve delete
do you want the heat to work in your car?
Old Jun 25, 2007 | 05:25 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
This has been covered many times, there is a button on the upper right hand side that is used for searching. Take 2 min of your time and check it out, you will find many pictures and diagrams.
Old Jun 30, 2007 | 05:42 AM
aretha's Avatar
Thanx for your reply no dont need the heater dont use it in winter
Old Jun 30, 2007 | 12:29 PM
IROCWPB's Avatar
Engine: 383ci TPI
Axle/Gears: stock
Run a heater hose directly from the port right under your radiator cap to the port on the front of your intake manifold, unless you're still using your oil cooler, in that case, from the manifold, to one of the pipes coming up from the oil cooler, out the other, to the port on your radiator. at that point all the hoses for your heater core and the valve can be removed, just remember to plug up the valve's vacuum line.
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
The_Phoenix
Feb 4, 2016 07:10 AM
lakeffect2
Aug 23, 2015 08:44 AM
BikeFarm
Aug 11, 2015 11:35 PM
