OVERHEATING!!!!!!!!!!!!!!!!!!
Old Jun 27, 2007 | 05:56 AM
SSMastiff's Avatar
Hello ALL, I have a 91 T/A 305 stock (TPI). The problem I'm having is that when I run the car about 20-30 miles when I stop the car the water in the over flow is way past the hot fill line and is boiling (big time). It will also stall out every time I stop at a light or stop sign when it's hot. I changed the thermostat. Also when the car is cool the color of the coolant in the radiator is green like new and the color in the overflow is brown. It runs fine other than that. No lights on the dash. Any help would be great........
Old Jun 27, 2007 | 03:06 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: OVERHEATING!!!!!!!!!!!!!!!!!!
do your fans work???
Old Jun 27, 2007 | 03:43 PM
SSMastiff's Avatar
The fan on the left works and the right side some told me that it only works when the A/c is on ??? So I dont know if the left side works.
Thanks for reply
Old Jun 27, 2007 | 03:49 PM
you may want to see if they are coming on every time. i had the prob to where my driver side one would not always come on. i just put a toggle switch in and now they both come on at the same time and it is so easy. i had to because i don't have working ac yet... if you would like to know how to wire in a toggle then let me know.
Old Jun 27, 2007 | 07:35 PM
SSMastiff's Avatar
Thanks, I was hoping that someone would know why the coolant is not circulating properly...
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
