Heater box Repair
Old Jul 1, 2007 | 09:46 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Heater box Repair
Last year, while I was doing the trans swap, I pulled out my dash to get some other wiring done back there, and to hopefully repair the temperature control door on the heater box. The door has been broken since I adjusted the cable (the lever broke while I was adjusting the cable) that runs from the control head. I found out then that the thing is really hard to get to and even harder to replace.
I now have a replacement control door, that was pulled from an 84, and I need to know two things: 1. Will the replacement work?; and 2. How do I get the one out of the 87 so I can replace it?
I'm kind of tired of having 170+ degree air blowing on my legs as I travel down the road at 60+ with the windows open, IN THE MIDDLE OF SUMMER!
Old Jul 3, 2007 | 07:01 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Heater box Repair
Okay, that idea is toast. I nabbed an upper mode door from a NON-A/C car, which had the lever operated side vents.
Another question arises: Since I have everything apart and can see what I need to do, what is the quickest and easiest way to get the heater box out of the passenger compartment? That's just about the only way I am going to fix the door I need to fix (and the other way isn't going to be pretty). I can get a heater box real easy, since there is around four thirdgens in my fav pick-your part yard, one of which has just arrived and only I have touched .
codeysabatini
Nov 10, 2015 04:07 PM
Formula8r89
Sep 22, 2015 04:24 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
buckshot63
Sep 10, 2015 09:15 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
