100 lbs. pressure in A/C, but not even cold
Old Jul 12, 2007 | 05:24 PM
taman86's Avatar
Car: '86 TA 305 F, '89 GTA 8
Engine: F 305 TPI, 8 350 TPI
Transmission: 700 r4
I hooked up my new A/C hose that I just bought, and started putting free-on into the system, only after 1 can (14oz.) the system showed 35 pounds of pressure, after 2 cans it was up to 50 pounds of pressure. The A/C worked for a week, but then started blowing warm air. I checked the pressure and it read 100 pounds. When the engine was turned on,with the compressor on, the pressure dropped down to 70.
This isn't right is it? I thought that it's supposed to take 3 cans to fill this system, ('86 305 F TA) and then would only be around 40-45PSI.
Old Jul 12, 2007 | 06:30 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Re: 100 lbs. pressure in A/C, but not even cold
Did you add refrigerant to an already semi-full system? You can't add R134 to R12 or your seals are going to get eaten (plus the switching is not right for 134). Also too much pressure will make your system run just as bad as too little pressure. Overpressurizing your AC system is not good.
Old Jul 12, 2007 | 07:10 PM
bowtienick's Avatar
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
did you evacuate the system? sounds like you have air in the system. you need to pull a vacuum to as close to 30" as you can.
diana227vegas
Jul 8, 2016 12:27 AM
hayesaw0210
Aug 23, 2015 11:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
