thermostat complications
Old Jul 14, 2007 | 03:54 PM
INFLAMES2468's Avatar
Car: 1990 Camaro RS
Engine: 350 TBI
i had a leak in my thermostat gasket a few days ago, so i replaced the gasket and the thermostat. Despite the small amount of coolant leaking onto the intake manifold, it ran fine, it didn't over heat or anything... but once i replaced the gasket and the thermostat, it'll idle at about 230 degrees, i have no idea why tho. what the hell's goin on with my car?
Old Jul 14, 2007 | 10:53 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Re: thermostat complications
what temp does it go to when your cruising?
does your fan kick on? and how accurate is your gauge?
Old Jul 14, 2007 | 11:49 PM
Car: 1990 Camaro RS
Engine: 350 TBI
it's usually about 190 and the fan does kick on. the guage is accurate to my knowledge, im gonna flush the radiator and see what happens, i think it may be clogged somewhere.
Old Jul 15, 2007 | 12:01 AM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
I had the same problem a while back, what temp thermostat are u running, on mine i replaced my thermostat and the parts store gave me a 190* instead of a 160* and thats what caused mine to overheat.
Hope this helps, blackandgoldl69
Old Jul 15, 2007 | 12:33 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
a 190* thermostat shoudln't cause you to overheat. even more so being I believe 190-195* is stock. all the thermostat is doing is controlling the lower end, or what is the coldest your car will run. it doesn't effect how hot it will get.
first thing I would do is verify the opening of your new thermostat. I have seen a few to be failed from the start. just put it in a pot of water and then bring it up to a boil and see at what temp it opens up and how quick it opens up as well as making sure it fully opens. if it checks out righ then you have something else going on.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
