Can I run A/C with 500hp?
Old Jul 15, 2007 | 11:26 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I'm in the process of taking the 305 out of my car and putting the 406 in. I am retaining the serpentine belt setup and want to know if I can still run A/C? My friend says I won't have enough engine vacuum to run the A/C. Whats that about? I am going to go with a better radiator to help keep temps down. I know I will probably have to use some sort of idle solenoid to kick the idle up when it's on. It would be easier to just put a non A/C heater box in it, but hey, every 11 second car needs A/C.
Thanks.
Old Jul 15, 2007 | 11:31 PM
Stephen's Avatar
Car: 87 GTA
Re: Can I run A/C with 500hp?
Vacuum has nothing to do with whether or not the AC is on or off, or working or not.
Run AC. you'll be fine.
Old Jul 15, 2007 | 11:38 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
yea i didnt think vacuum had anything to do w/ it..jus run your hoses underneath so it looks clean
Old Jul 16, 2007 | 05:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I use a throttle kicker solenoid from Holley, IIRC.
JamesC
Old Jul 25, 2007 | 02:55 AM
LilJayV10's Avatar
Engine: 406 Roller
Thanks for the input. Next is going to be what radiator I use. I have a griffin 31x19 but it's going to require some modification to run it. I know some people swear that a stock radiator is enough, but my stock 305 runs hot sometimes, I just don't know.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
lakeffect2
Aug 23, 2015 08:44 AM
BikeFarm
Aug 11, 2015 11:35 PM
