Fan not turning on, With new parts
Old Jul 17, 2007 | 08:27 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Ive changed the fan switch, and coolant sensor. The fan turns on when i jump it from the battery but thats it. What could be the problem? the relay?
Old Aug 22, 2007 | 11:08 AM
xbcrguy182x's Avatar
Re: Fan not turning on, With new parts
Fan relay?
Old Aug 22, 2007 | 01:10 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
X2 or the fusible link for the fan relay. Find the relay....Red lg wire is the constant power from the fusible link = 12V constant, Black-Red lg wire is the output to the positive fan terminal = 12V when fan on, Brown wire is the switched power from the fuse box (C/H FAN 20amp) = 12V ignition on, and Green-White is the trigger for the relay to come on = grounding. The grounding trigger comes from 2 sources...the fan switch or the ac switch inside. If the fan doesnt come on with AC on OR when preset cooling temp is reached, then you either have a blown CH/FAN fuse (brown wire circuit), a blown fusible link (red wire circuit) or simply a bad fan relay. Use a volt-meter to test Red - constant 12V and Brown - ignition 12V 1st , and then move on to swapping the relay if those are good.
RazorN8
Jan 7, 2022 11:44 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
TA8487
Aug 16, 2015 12:21 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
