Timing retard and cooling
Old Jul 19, 2007 | 09:23 PM
GWW's Avatar
GWW
Car: 89 Iroc-Z
Engine: 5.7
Transmission: 4 spd auto
I have (had) my base timing set at 8 degrees. It is also programmed into the chip that way. I took my car to get it smogged and it passed, no problems. However as our weather has gotten hot 100+, I began to notice an overheating tendancy at idle. I had my radiator recored and that took care of a lot of it. At least I stay under 232 for now. My fans are set to come on at 180 along with a lower temp primary coolant fan sensor switch in the block and 180-thermostat. Fans are working correctly, blocks not plugged, new Stewart pump too.
Anyway the 232 still makes me uncomfortable and through trouble shooting I noticed my timing was set at 3 degrees. Smog guy must have done this. I put it back to 8 do you think this is enough retard to cause the heating on hot days on idle only? I'm still thinking it's airflow because as soon as I get moving it comes right down.
GW
Old Jul 19, 2007 | 11:12 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Timing retard and cooling
Mine is set at 8° right now. During 95° days, it still doesn't get hotter than 190°F with the air on.
Coolant flush perhaps? It's hard to say how long you're stuck in traffic for. If it's for 10 minutes of constant stop and go, I could see the temps hovering up around 220 or so.
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
bamaboy0323
Sep 3, 2015 06:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bryan F
Aug 18, 2015 02:28 PM
