Dual Fans just stopped working. . .
OK guys, I have been battling some other problems non cooling related, I finally got all that stuff squared away, my fans were both working correctly. Primary comes on at 185, and secondary comes on at 185 due to different sensor in pass. side head.
All was well, today I was just rechecking timing after driving a little bit, and i went to shut the car off and realized my fans werent funning and the car had crept up over 235deg !!! eek!
Anyway, I put the car into diagnostic mode to see if the fans would come on and nothing.
Im getting burnt out on fixing problems
Need some guidance as to where to start on this one?
Just as some FYI, I have recently replaced my battery with a red top optima, and new alternator as well. everything was working after the new stuff was installed.
Could I be looking at a bad fuse?
Thanks in advance!
Need some guidance as to where to start on this one?Just as some FYI, I have recently replaced my battery with a red top optima, and new alternator as well. everything was working after the new stuff was installed.
Thanks in advance!
Re: Dual Fans just stopped working. . .
I figured out what was wrong. Apparently the large connector with 5 or 6 wires that is between the battery and the radiator isnt getting a good connection. I wiggled that and the fans started working again
Anyway, is there a way to replace that harness connector? what is it called? Its kinda long and flat.
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
