Why are my fans turning off after the A/C has been on???
Old Jul 27, 2007 | 03:20 PM
im4darush's Avatar
If I turn the A/C on, the fans will turn, run for a bit, on and then turn off. At that point the A/C compressor begins to cycle. I assume from high line pressure. What is the normal operation? Should they turn on when the A/C is on and STAY on?
Old Jul 27, 2007 | 04:35 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Why are my fans turning off after the A/C has been on???
I'm assuming you have 2 fans on your car.
Driver side should turn on and stay on with the A/C. The passenger side will turn on when the high side pressure gets to 233 psi. On my car, the passenger is sometimes on, sometimes off. It's also controlled by the temperature sensor in your passenger head. (Mine has been changed out to a 200/185 on/off sensor)
Now if you have a pre 1988 car, I believe the passenger side isn't controlled by the A/C and is only controlled by engine temperature. In that case, it would be cycling on and off whenever the coolant temp sensor in your passenger head has reached it's turn on temp.
Old Jul 28, 2007 | 08:46 AM
im4darush's Avatar
My car is an 87 350 formula with dual fans.
Old Jul 28, 2007 | 08:53 AM
im4darush's Avatar
The primary runs when I first turn the A/C on, and then turns off. At that point, the A/C compressor begins to cycle.
Old Jul 28, 2007 | 09:04 PM
89irocMike's Avatar
My car is doing the same thing. It is a 89. I am tempted to wire the fans to stay on the whole time it is in ac mode. Theres no way it can be cooling effeciently withe fans turning off with the ac compressor engaged
Old Jul 28, 2007 | 09:14 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
The extra fan is only neccessary at low speeds and stays off when at hiway speed. That is the reason for the pressure switch.
Old Jul 29, 2007 | 06:45 AM
im4darush's Avatar
Im talking about the primary fan. Even when I bypass the pressure switch, the fan is still not running.
RazorN8
Jan 7, 2022 11:44 AM
evilstuie
Jan 9, 2020 08:29 PM
Papaginos
Sep 27, 2015 03:29 PM
BikeFarm
Aug 11, 2015 11:35 PM
