Fan runs all the time?
Old Aug 2, 2007 | 12:48 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
In an '87 5.7 IROC, is it normal for one of the fans to run whenever the key is on and the other to come on with the A/C? Just wondering if it's normal or if I have a bad temp switch.
Old Aug 2, 2007 | 04:03 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: Fan runs all the time?
As far as I know, `88 and up the secondary fan comes on when the air is turned on while driving under 40mph or the engine temp exceeds 234. Not sure about how your primary works, I think it is different than the `88. Check under Search and you should come up with more info than you know what to do with.
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
justin57
Aug 20, 2015 07:05 PM
