Oil in coolant
Old Aug 12, 2007 | 07:17 PM
TSCaboose's Avatar
Oil in coolant
I recently bought a 1985 camaro z28
its a 305 5speed
one i got it i had the oil changed and put new coolant in it.
the other day my car was over heating and i pulled over to check it out, the coolant was boiling and there was what looked like oil in it.
what should i do?
Old Aug 12, 2007 | 11:25 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: Oil in coolant
Probably a blown head gasket
Old Aug 13, 2007 | 10:20 PM
Ford2transam's Avatar
Car: 1983 Trans Am ALL STOCK which is go
Engine: 305low
Axle/Gears: stock
Re: Oil in coolant
Chanced are blown head gasket or warped head or both
Check your compression
IF one or more cylinders are low pull the head have a machinst check it out (mambe even port the valves while it's off????) and replace gasket.
Old Aug 14, 2007 | 02:39 AM
TSCaboose's Avatar
Re: Oil in coolant
i had a test done on it, there was some gasket that was making the oil drip in there. but the real problem was my thermostat was shot, it was stuck closed, not allowing coolant into the engine
Old Aug 14, 2007 | 09:34 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: Oil in coolant
TSCaboose, you may want to check out the archives in cooling. There are a lot of good ways to keep your car running cool from people who know F-Bodies.
Old Aug 19, 2007 | 10:29 PM
Engine: 305low
Axle/Gears: stock
Re: Oil in coolant
Whereas i admit i am new to the f-bodies heck Gm period. No matter what brand motor is i've noticed if oil in coolant or vice versa they tend to be similar problems. Has for the thermostat shot it could have resulted in to much pressure on the gasket causing a leak (or drip). outta curoisity what gasket was it?
Old Aug 21, 2007 | 04:04 AM
TSCaboose's Avatar
Re: Oil in coolant
uhm it was the gasket around the thermostat, to be honest, i dont even know if there was oil in the coolant in to first place. i could have just been dirty or something, i drained it and put some new coolant in and it still looks fine.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
codeysabatini
Nov 10, 2015 04:07 PM
Stryker412
Sep 20, 2015 06:59 PM
