a/c rehab
Old Aug 14, 2007 | 07:39 PM
OS3Fleming's Avatar
Car: 1984 Camaro Z28
Engine: 357 SBC
a/c rehab
I have read the links, but want to know what parts to buy.
Parts I got already:
Heater Core
Condensor
Parts I ordered:
Compressor w/ Clutch
Hose's
Receiver drier
Would I need any thing else
Rich
Old Aug 14, 2007 | 09:02 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Re: a/c rehab
I am assumming that when you said reciever drier you mean accummulator. a reciever drier is used in expansion valve systems. Third gens use an orifice tube setup, so you need an accumulator. Speaking of that, get an orifice tube and a clutch cycle switch. The switch fails all the time, and when you order one, they will have one for 134A and the original 12 one. You will also need an evaporator as well.
cheers!!!
Old Aug 14, 2007 | 09:57 PM
OS3Fleming's Avatar
Engine: 357 SBC
Re: a/c rehab
Kluase,
so where is the evap located....I have the Accumilator that was original to the car.....but I am changing that out.....Sorry kind of new at this thats why my dad will be taking charge.
Where is the orfice tube located....
Rich
Old Aug 14, 2007 | 10:41 PM
Car: 83 z28
Re: a/c rehab
The evaporator is located under the dash almost right beside the heater core. look for the entrance of the ac lines into the firewall and the evap is on the other side.This is the item that does the heat exchange from the freon and makes the car cool. The orifice tube, on the other hand will be at the exit of the high side line going into the evaporator.
Old Aug 14, 2007 | 11:02 PM
OS3Fleming's Avatar
Engine: 357 SBC
Re: a/c rehab
Now even though it keeps pressure will I still need to change the evap or can I vac it out good and reuse it.
Old Aug 15, 2007 | 10:07 AM
Car: 83 z28
Re: a/c rehab
As long as you have pressure in the system, and have no leaks, then it would seem ok to me that all you have to do is flush the evaporator and continue to use it.
Cheers!!!
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
