Why are the coolant lines going under the engine block??
Old Aug 15, 2007 | 12:13 PM
camar0rs's Avatar
Coolant lines appear going under the engine block??
Does anyone have a coolant flow diagram for this car, i would love to see how the cooling system really works... I have a chiltons book but it doesnt show jack about this....
Old Aug 15, 2007 | 12:26 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: Why are the coolant lines going under the engine block??
well theres 2 lines that go to your oil filter adapter. it has a coolant system on the oil filter adapter.
Old Aug 15, 2007 | 08:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
not all cars have an oil cooler
if the lines are metal, and coming from the passenger side of the radiator, they are the cooling lines for the transmission, provided you have an automatic
Old Aug 15, 2007 | 08:57 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The Optional factory oil cooler has 2 hardlines that go right under the front of the motor, like right under/behind the balancer, is that what you see on your car?
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
lakeffect2
Aug 23, 2015 08:44 AM
AkDrifted
Aug 17, 2015 07:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
