where is the radiator a good spot for temp guage sensor
Old Aug 26, 2007 | 01:02 PM
supreme4life's Avatar
I bought a mech. Temp guage and put the sensor in the radiator I have a summit aluminum radiator it has a extra plug for that or a fan switch. Is the radiator a good spot or should I get a therm. Housing with a plug and put it there?
Old Aug 26, 2007 | 01:35 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
Re: where is the radiator a good spot for temp guage sensor
I would make sure the sensor is as close to the incoming coolant as possible, but yes the best place would be on the thermostat housing.
Old Aug 28, 2007 | 05:47 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
supreme4life, as hgffrank says, the thermostat housing is the best and easiest place to install the sender for the mechanical water temp gauge. Not to change the subject but how was the install for your new Summit aluminum radiator? I have heard that they are supposed to be a direct fit but require some modifying to get it in?
Old Aug 28, 2007 | 06:56 PM
The radiator was a direct fit with no mods . Slid right in place
Old Aug 28, 2007 | 08:27 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Thanks for the reply, I am close to getting the same radiator.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
355sbcTPI
Aug 19, 2015 04:38 PM
