Reverse cooling flow on my Cross-fire ?
Car: 1983 Recaro Edition T/A
Engine: ex-CFI 305
Transmission: TH-700
Hi everybody
I need to buy a new water pump for my 1983 305 Cross-fire Recaro Ed T/A.
JEGS offers a water pump that fits all 5.0-5.7 Chevy SBC from 1977 to 1990, "excepted Reverse rotation".
The pump is number 555-51033. Given that the CFI is a very special a couple-of-years-only engine, I wouldn'tbe surprised if it was actually a reverse rotation engine...
Can somebody confirm ?
I want this pumps because it's already painted black. Like all my engine after its rebuilt next year.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Reverse cooling flow on my Cross-fire ?
The Crossfire(LU5)305 uses a standard rotation water pump if it still has the original v-belt pulleys.If would use a reverse rotation water pump only if it had been converted to a serpetine belt setup up.That said the pump P/N you've given will work on your CFI motor.
As far as paint you could use a good hi-temp black on the correct pump.
Pac J
May 17, 2020 10:44 AM
