Anybody Run AN fittings on the Cooling System?
Old Sep 10, 2007 | 11:19 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I am converting my Griffin radiator to -20AN. I just picked up a billet specialities water neck and was wondering if there is a better water neck to use with my HSR and 58mm TB? I want a quality piece, so I figured the Billet Specialities would be the way to go. Anybody do this with a TPI configuration? What did you use for a waterneck? Here is a link to the waterneck I purchased.
http://www.billetspecialties.com/ite...cid=88&pid=499
Old Sep 10, 2007 | 11:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Anybody Run AN fittings on the Cooling System?
For me it's always seemed like it would be more of an appearance mod than anything else, and with the price of large fittings and hose it's a pretty expensive one, too.
Old Sep 11, 2007 | 09:14 AM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Yes it is to a degree. But I also want piece of mind when going 100+ at 6500 RPM that everything is holding together.
Old Sep 12, 2007 | 02:36 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Anybody Else use this style of housing with their TPI?
Old Sep 22, 2007 | 05:32 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
To be honest, if people are spending the $$ to swap to AN and SS lines for their cooling, they probably arent running TPI. I have a CSR billet waterneck on mine, though my pump is the Meziere remote mount type.
midge54
Dec 27, 2019 04:14 PM
Fast355
Dec 2, 2016 06:33 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
matthew911
Aug 12, 2015 09:38 AM
