OVER HEATING PROBLEMS!!!!!!!!!!
Old Sep 22, 2007 | 11:58 AM
brandon_mckay's Avatar
Car: 1988 RS Camaro
Engine: 2.8l/ hopefully boosted 2.8 soon
Transmission: blown up t5
Hi i am having over4 heating problems wit my 88 2.8 rs let me tell you a little bit about the situation first i bought the car last year when we pulled it into the yard it over heated we didnt know why but had to pull it into that garage because it was being put away for the winter anyways we recently brought it here to my house and have been working on it we replaced the thermostat and other basic tuneup like setting the valves my fan isnt hooked up now and wasnt when i bought it noticed when i got it here that the idiot i bought it from had it so you just lay the wire over the positive terminal of the battery post for the fan to come on so i looked for the relay and couldnt find it so i did the only thing i knew to do and that was i just brought it to a switch in the car . som other things the car has is a bigger exhaust the egr (i think its called that the thing the vacuum line goes to which routes exhaust into the throttle body ) isnt hooked up right now another thing i thought it might be is the sensor doen on the exhaust pipe isnt hooked up right the guy just has the wire twisted together. i am 16 and all help would be much appreciated thanks
Old Sep 22, 2007 | 01:16 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: OVER HEATING PROBLEMS!!!!!!!!!!
well since the fan was messed around with, check to see if its blowing on the motor, not away. Check to see if the air dam is still on there....let us know how you make out
Old Sep 22, 2007 | 03:22 PM
Car: 1988 RS Camaro
oh another thing it wasnt at highway speeds actually more on the low end between 0 30 km an hour i only drove it up and down the street a couple of times and then let it idle this is because it isnt on the road yet
Old Sep 22, 2007 | 06:06 PM
fbird92's Avatar
Car: '92 firebird
Engine: 305 HO
Transmission: 700R4 TCI performance
Axle/Gears: 10 bolt disc brake 3:42 slp auburn
I would prob change the water pump. water pump could of went bad and would cause over heating problems. If you change that you might as well change the antifreeze also.
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
mustangman65_79
Sep 1, 2015 03:51 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
chazman
Aug 22, 2015 02:01 PM
