Replacement Compressor Studs?
Old Sep 20, 2007 | 06:27 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I bought a serpentine kit from a junkyard (well, I pulled all of the serp crap from a junkyard) and was wondering if anyone could point me to a source for the two studs that hold the compressor to the bracket? GM says they don't have anymore, and I can't find them anywhere online. All of the local yards have a "minimum purchase" so that's out as well, as I can't think of enough stuff to make a $50 purchase worth it.
Old Sep 20, 2007 | 06:33 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Re: Replacement Compressor Studs?
I don't recall any studs holding the ac compressor in.
Old Sep 20, 2007 | 06:38 PM
Axle/Gears: 3.27 BW
There's a bolt at the bottom holding it in on the serp setup, and then there's two studs that go in each side, and a nut goes on the back of the studs to tighten down the braces that support the passenger side bracket.
evilstuie
Apr 14, 2016 08:52 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 25, 2015 07:34 PM
LT1Formula
Aug 20, 2015 09:36 PM
rh76camaro
Aug 15, 2015 12:48 PM
