single fan ,not working
Old Sep 24, 2007 | 04:56 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i put new relay and fan switch on car and it ain't turning on. if i jump the relay it turns right on.but wont come on by itself.i even put a brand new ecm in this car.
Old Sep 24, 2007 | 06:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: single fan ,not working
have you checked to see of the fan switch is working properly? ig you ground the switch does the fan turn on?
Old Sep 26, 2007 | 04:53 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
do i just ground the wire for fan switch out?
Old Sep 26, 2007 | 07:43 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Yes.
Old Sep 28, 2007 | 02:58 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well grounded wire for fan switch, turned on fine.the sensor (brand new)came w/ some sort of factory red sealant on it could that be the prob?
Old Sep 28, 2007 | 04:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the red stuff is pipe dope or telfon lube, not problem there. I know that my old stock fan switch didnt turn on until almost 240 degrees, which is way too high to be worth a damn. A good, lower temp hypertech or jet fan switch will work much better.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
