at wat temp our r cars overheating at
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: at wat temp our r cars overheating at
i feel that anything over 210-220 is overheating. But as for the gauge in my car, the red starts as about 250
The factory fan switch TURNS THE FAN ON at about 235°. So as far as the factory is concerned, anything UP TO that, is totally normal, and the engine does not require cooling AT ALL until it reaches that temp.
So no, 240° is not "overheating".
Which is not to say that you might not want it to run cooler than that. Just keep the difference straight between "preference" and "defective".
The stock gauge is not accurate, as being any kind of reliable indicator. Any resemblance to actual engine temps that its reading might bear, is mostly accidental. About all it's good for showing "normal/abnormal", "warmed-up/not-warmed-up", stuff like that. Don't try too hard to put numbers on it. That's one reason there's no numbers at all on most of them.
Linson
Aug 21, 2015 02:12 PM
