fuel type overheat question?
Old Oct 27, 2007 | 05:49 PM
jed5161's Avatar
Car: 88 Trans Am GTA
Engine: 383 Lingenfelter/AFR 670 hp
Transmission: 700r4 3500 stall
Axle/Gears: 3.90 9 inch
anyone ever have any problem with the car running hot/overheating only because you switched fuel? i've always ran premium octane from bp. recently we tried some 100 low lead aircraft fuel from the local air port. Going down the highway it was runnin maybe a 10-20 degrees warmer, but in town it overheaded quickly. Ran that tank dry and filled it up with premium, didn't have any problem since
Old Oct 27, 2007 | 10:28 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: fuel type overheat question?
Isn't aircraft fuel kerosene?
Old Oct 27, 2007 | 11:46 PM
88-I.R.O.C.'s Avatar
Car: 1988 IROC-Z
Engine: LS2
Axle/Gears: Strange 60 3:73
100 LL should not be run through a car unless you're running no cats. If you have cats, the lead will take them out. It shouldn't really run hotter. Perhaps a radiator flush would fix the problem. I know on older non ecu cars the timing should be advanced if you want to use 100LL to stop pinging. Newer ones should self adjust the timing, but eventually you can say bye-bye to the cats. I believe 100LL is hard on the motor, but an occasional tank will not hurt.
100LL means "low lead" comparing to old leaded gas. Jet fuel is more like a kerosene mixture. AVgas is still gas.
Old Oct 31, 2007 | 05:49 PM
jed5161's Avatar
yea i removed the cat a while back. it was fall'n apart internally blockin off exhaust and wouldn't run worth a damn over 3000 rpm. which sucked with a high stall convertor! anyways...i was just tryin the low lead fuel since it was hell of alot cheaper than cam 2 race gas. VP fuel we got here is like 6-8 bucks a gallon pending octane rating
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
colton_carlson
Mar 8, 2019 12:21 PM
lakeffect2
Aug 23, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
