Does anyone know how to wire an electric water pump? If so can you post a diagram?
wire from battery to a switch, other plug ont he switch to a fuse to the water pump, other one from water pump to ground. Not that hard
if the wire run is going to be long, put in a relay. use the switch to activate the relay, thus keeping the power wires shorter and lessening the voltage drop
