Thermostat leak and tick noise?
Old Nov 2, 2007 | 02:35 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Today I noticed a small leak from what looks like the bottom of the water neck. Should I try and just fix the leak by putting some RTV around the whole base of the water neck? Or should I remove the water neck and thermostat and reseal it?
Another thing, when I squeezed the upper radiator hose you can hear a tick/clicking noise. Is that normal to hear the thermostat tick/click?
Old Nov 5, 2007 | 09:04 AM
xbcrguy182x's Avatar
Re: Thermostat leak and tick noise?
First, make sure the hose clamp is tightenned and seated in properly. If its still leaking, take out housing, scrap off the old gasket material, and reseal it with gasket and rtv. Might as well replace the thermostat while you are at it.
Old Nov 5, 2007 | 09:25 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Pull the thermostat housing, check it and the manifold for corrosion or pitting that may cause coolant leaks. This would be a good time to drain the old coolant and refill with new and replace the thermostat. As for thermostat gaskets, I've always had good luck with the Fel Pro shown below.
http://www.autozone.com/R,APP749045/...ductDetail.htm
Old Nov 5, 2007 | 09:29 AM
Do you use just the gasket, or o-ring and gasket?
Old Nov 5, 2007 | 02:20 PM
Rich92 RS's Avatar
Transmission: T56's
Ok, sounds good. I'll be replacing it all tomorrow then. Anyone know why the thermostat would make a clicking noise when the upper hose is squeezed? Defective?
Old Nov 6, 2007 | 02:10 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
The thermostat shouldn't be clicking, it sits in one spot and doesn't move so part of it is probably broken.
Old Nov 6, 2007 | 11:30 AM
Rich92 RS's Avatar
Transmission: T56's
I replaced the thermostat and gasket, and I think I know what the ticking noise was. I'm pretty sure it was the "Built-in bypass valve to remove air pockets" Does anyone else have this? If you don't know what I'm talking about I can get a picture just lmk.
Bubbajones_ya
Jul 6, 2024 08:32 PM
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
BWilcox
Sep 20, 2015 12:19 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
