Heat Problem.
Old Dec 3, 2007 | 11:14 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Heat Problem.
88 camaro 5.7L
I turn the heat on and it blows out pretty warm at first then drifts into a +~5* ambient temperature. I can't figure out the problem Suggestions?
Old Dec 4, 2007 | 07:12 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Heat Problem.
Assuming that the temperature contols inside the cabin all work as they should-
Possible problems; restricted heater core, failing heater control valve, loss of vacuum to heater control valve, weak or collapsed heater hose, loss of circulating system pressure... Coolant has to flow in and out of the heater core. If the system is weak or plugged, you'll need to find out where. Or it could be as simple as replacing the heater control valve found under the hood.
How long has it been since the cooling system has been serviced? Do you need to frequently add coolant?
Old Dec 4, 2007 | 08:20 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: Heat Problem.
Well I have only had the car about a month. I'm not sure how long it's been since the cooling system was serviced. If the heater core was clogged it wouldn't blow hot air for even a second would it?
Old Dec 4, 2007 | 09:20 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
Re: Heat Problem.
if the area where the heater core was blocked it would not blow hot air if the heater core was plugged it would not blow hot air or circulate coolant if your heater valve didnt work you could by pass it to run constant coolant through your lines, unlikely your vacuum lines are colapsed, pull of the kick panel under the pass. side and see if the "door" opens and closes as the vacuum is pressurized in the canister if yes then you dont have a vacuum problem. let the car idle for a while or take it for a ride and feel the heater hoses that run from your intake to your heater core, if the outlet line is hot then your core isnt plugged. just keep looking.
Old Dec 5, 2007 | 07:26 AM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: Heat Problem.
Good stuff.
Thanks I'll get to that and report back
Old Dec 9, 2007 | 11:18 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: Heat Problem.
Ok well I looked under the dash and the door opens / closed on max. The linkage from the hot and cold on the controls turn something and all the lines comming out and in on the heater control valve are hot as hell. Next idea?
Old Dec 10, 2007 | 11:03 AM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: Heat Problem.
I GOT IT TO WORK!!!! the Vacuum line that goes on the top of the heater control valve wasn't sucking very hard to I used a Vacuum line off the back of the intake and it works perfectly. Is there anything that I should worry about by doing this?
Old Dec 10, 2007 | 05:30 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: Heat Problem.
not sure, but there's a thread showing how vacuum lines are run for most of the 3rd gen engines. The thread is in the sticky section & should show you what that line was originally made for
Old Dec 10, 2007 | 08:33 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: Heat Problem.
Thanks for the info but could you post a link because I went threw most of it and I can't find the picture / article.
Old Dec 11, 2007 | 08:50 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: Heat Problem.
Here is the link. If it doen't work go back to the sticky, the link to AZ vacuum diagrams works from there.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
https://www.thirdgen.org/forums/faq-...-diagrams.html
Old Dec 11, 2007 | 09:41 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: Heat Problem.
Thank you sir.
Class, please Refer to the first link in the post quoted, and the second to last link on the page retrieved. I connected the hose that is labled ,"to hvac" to the top of the heater control valve. Am I doing damage?
- Thanks
Old Dec 12, 2007 | 12:14 AM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
Re: Heat Problem.
This thread is right on time.........Im having the same problem. It freakin 15 degrees on some nights in utah. And im NOT GETTTING real HEAT! I did an AC delete an now my heat doesnt blow hot. All I removed was the compressor and the evaporator(canister and lines).
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
