heater core hoses
Old Dec 16, 2007 | 03:10 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
heater core hoses
im replaceing my heater core and i got every thing taken apart i just cant get the heater hoses in the engine conpartment off . eny tips or eny thing i should know that would help?
Old Dec 16, 2007 | 03:40 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: heater core hoses
spray with pb blaster or wd40 and possibly use a hose tool if you can get one. it looks like this.
http://store.summitracing.com/partde...5&autoview=sku
autozone napa carquest all carry them I think.
Old Dec 16, 2007 | 05:25 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
razor blade or knife
be careful be easy on the heater core necks or you can make the core leak
Old Dec 16, 2007 | 05:28 PM
atomicskr's Avatar
Razor blade x 2!
I just found my heater core leaking... how difficult is it to replace?
Old Dec 16, 2007 | 05:31 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by atomicskr
Razor blade x 2! I just found my heater core leaking... how difficult is it to replace?
I used channel locks and a good twist or two. The following thread may be of interest:
https://www.thirdgen.org/forums/tech...e-82-86-a.html
JamesC
Old Dec 17, 2007 | 07:53 PM
Car: 1992 Camaro RS
Engine: 305 TBI
i didnt use a razor or knife i just did what jstoltz said with the wd40 and that tool and it worked very good
Old Dec 18, 2007 | 08:17 AM
jstoltz's Avatar
glad to help. most of the time the right tool will definitely work better than the cheaper way.
Old Dec 24, 2007 | 01:41 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I was just about to create a new topic about this.. Anyway, I have my dash all ripped out ready to do this. Is there any thing I should know before I take apart the heater-box? Is there a filter in the heater-box?
Old Dec 24, 2007 | 02:11 PM
cainestl's Avatar
Car: 1985 Trans Am
Hi the names Caine. Im in need of some help and you seem like you give good advice. I have a 85 tpi transam and just dropped a 87firebird crate 350 in her. She runs good unless i run street for more than 10min then she get up to 220-235 degrees.I have a new stock radiator,185degree thermostat, not loosin coolant, and i just got the system flushed.Do you think the water pumps to blame? Also which stock 305 parts do you recomend me changing to upgrade and benefit the performance of my 350. I heard i need to change the 305 injectors to 350 injectors. Is this true. Any help is highly appreciate. Thanks
Old Dec 24, 2007 | 03:22 PM
JamesC's Avatar
No.
JamesC
Old Dec 24, 2007 | 04:28 PM
Kevman's Avatar
Engine: 2004 LQ4
Ok, I found where most of the Antifreeze smell is coming from. The heater core was leaking, and the air was pushing the hot antifreeze in to some of the insulation inside the heat ducting. So looks like I get to rip that out, too.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
