I need help to help someone.
Old Jan 12, 2008 | 12:14 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Another member on the forum, Dalton, has a problem with his car. With a 89 formula 350 chip in the 89 formula 350 computer, the fans kick on at around 230 degrees but with the same computer and his 87 5.0 tpi chip, one fan runs all the time. It is a stock chip but what is the difference? Both cars have dual electric fans and both are auto trans. Why is this?
Old Jan 13, 2008 | 02:00 PM
all4u's Avatar
Car: Firechicken
Re: I need help to help someone.
I guess no one understands the problem.
Old Jan 13, 2008 | 05:58 PM
topradman's Avatar
Car: 91 Z28
Engine: Super Charged 414 FI Roller Mtr.
Transmission: CK Perf. 4L80E Manual W/Transbrake
Axle/Gears: 9" Ford 3.25
HI TOPRADMAN HERE, I GOT AN IDEA......SUMMIT HAS A FAN TEMP SWITCH THAT KICKS THE FANS ON MUCH SOONER AT LOWER TEMPS. CHECK IT OUT....
Old Jan 13, 2008 | 09:37 PM
all4u's Avatar
Car: Firechicken
First, don't type in all caps! No need to shout. Next, re-read my first post. All we did was swap chips, nothing else, what would a temp switch do for me?
Old Jan 13, 2008 | 10:31 PM
topradman's Avatar
Car: 91 Z28
SORRY, NOT SHOUTING, I ALWAYS TYPE IN ALL CAPS.....ANYWAY, AFTER REVIEWING HYPERTECH COMPUTER CHIP INFO, LOOKS LIKE THE CHIPS ARE DIFFERENT PART NUMBERS BETWEEN THE 2 APPLICATIONS. I RECENTLY HAD TO REPLACE MY COMPUTER AND INSTALLED A USED COMPUTER OUT OF A V6 FIREBIRD. I SIMPLY REMOVED MY CHIP AND INSTALLED IT IN THE REPLACEMENT COMPUTER AND HAD NO PROBLEMS WITH PERFORMANCE OF FAN ISSUES. APPEARS THEY ALL USE SAME COMPUTER BUT CHIPS ARE DIFFERENT BETWEEN EVEN 305 AND 350 TPI'S.......BY THE WAY, ARE YOU INSINUATING YOU WOULD LIKE TO HIT ME IN THE BACK OF THE HEAD FOR TRYING TO HELP??????? HMMMMMMM........ IF YOU HADN'T PUT IN THE 230 DEGREES I WOULDN'T HAVE MENTIONED THE TEMP SWITCH. THOUGHT MAYBE YOU WERE NOT ENJOYING THAT TEMP EITHER........HMMMMMMMMM......CHECK OUT A WEBSITE THAT OFFERS REPLACEMENT CHIPS FOR THESE TWO VEHICLES AND SEE IF THEY ARE THE SAME PART NUMBER...........I'M FINDING THEY ARE DIFFERENT MYSELF.......
Old Jan 14, 2008 | 10:34 AM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
There is a ThirdGen forum for PROMs, something I'd like to get into later. Anyway, from reading that forum it's easy to see that there are differences between chips produced in different years. Might want to take this question to the PROM section for a more specific answer.
roysatikas
Sep 22, 2015 08:15 PM
3.8TransAM
Jul 15, 2005 07:01 PM
Dirty Dave
Carburetors
Jul 6, 2005 09:23 AM
3.8TransAM
Jun 1, 2005 03:55 PM
JMBoriss
Oct 14, 2001 12:43 PM
