Fan Problem... To Hot...
Old Jan 22, 2008 | 01:21 PM
jreze8's Avatar
Car: 1991 Iroc Z28 Camaro
Engine: 5.7L V8 350CI
Transmission: Stock
Axle/Gears: Stock
My left fan does not kick in till my 1991 Z28 350 TPI gets to about 230-240 and the right side never kicks in even with the ac running... Someone please help cause my car won't fight the summer like it is... This is Texas... Radiator is clean, thermo i believe is new, and fins are clean...
Old Jan 22, 2008 | 01:51 PM
xbcrguy182x's Avatar
Re: Fan Problem... To Hot...
Check your relays. Also, your fan switch may be seeing its final day. If you have to change the fan switch, swap it with a aftermarket one. They can turn on the fan as low as 180 instead of 220(stock)
Old Jan 22, 2008 | 01:56 PM
jreze8's Avatar
Transmission: Stock
Axle/Gears: Stock
can you buy a switch with a diff temp setting?
Yeah. Just check summitracing.com
Old Jan 24, 2008 | 12:24 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
I run the fan switch that's on at 200° and off at 185°. Works great for summer and winter. Keeps the car cool but doesn't run all the time.
Are you still on the original R12 A/C? You might be a bit low on R12. If that's the case, your passenger fan probably isn't kicking on because it's not getting high enough pressure when the A/C is running.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
