Shroud Bolts
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Shroud Bolts
Well, I've known this for a while, but I seem to be missing a bolt on my fan shroud (single, stock, electric). It doesn't cause any noise, really, but I'd rather have it completely attached so it doesn't decide to cause noise.
What type of bolt is needed, if it's a special kind, where should I be able to find it?
Thanks.
Thanks.
Re: Shroud Bolts
Pay attention to the hole; you may find that the reason there's no bolt there, is because there's also no Tinnerman clip in the hole. They have those hanging on that carousel, too; just get the size that matches the bolt.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Shroud Bolts
probably the same ones as the ones on the top of the rad support for the manual fan shrouds as well
if so then i have millions of them from past part outs
and clips too
a pic, length, and diameter and i could scratch some up
if you have no other luck
good luck
and clips too
good luck
UltRoadWarrior9
Sep 2, 2015 08:24 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
