tranny to red cooling lines (what SS braided size line and AN - fitting Size?)
need to run flexabile braided stanless stell line with AN fittings
i want to run number 4 - AN line what size fittings, but what size line and fittings are the stock ones from a 700r4 to the rad? if anyones done this can you post sizes ect? thanks
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: tranny to red cooling lines (what SS braided size line and AN - fitting Size?)
The fittings on the rad and the transmission are 5/16 inverted flare. Use an Aeroquip FCM-2111 to convert them to -6.
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Summit lists those under AER-FBM2111.
Engine: 383 Carb
Transmission: 4L60
Right, those are the same part. FCM is on a card for retail sale and FBM is bulk.
toronto formula
Nov 10, 2015 06:17 AM
