Coolant on the pasenger side??
Old Feb 28, 2008 | 12:02 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Ok, I had track in some mud in a few days ago and took both mats out to wash and found a yellow sticky dryed up liquid on the floor of the passenger side. I wiped it up a little pissed off and then two days later I looked again and it was there again. My first guess is that it is coolant for the coil in the dash. Problem is my coolant is green not yellow. So has anyone had there coil break and did it drip to the carpet? Any guessing would be good to I’m just try to get a idea what is going on before I take it apart this weekend.
Old Feb 28, 2008 | 12:06 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Coolant on the pasenger side??
animal living in your dash leaving you presents?
if it's coming from that i would also assume it should be green, but possibly with buildup it's finally rusted through and coming out with with buildup?
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Well, consider the other possible sources of moisture inside the car. Water is usually water, but it can stain carpets.
However most likely, if it smells like coolant, looks like coolant, it probably is coolant. Time to examine your heater core. Different color coolant or not I'd still look it closely.
Old Feb 28, 2008 | 01:50 PM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
Chances are your heater core cracked. I had the exact same thing happen just replace the heater core and clean up all the coolant thats what i had to do.
New2Chevy
Sep 28, 2015 12:35 AM
LittleFranks
Sep 17, 2015 12:22 PM
Bstrang6
Sep 8, 2015 04:29 PM
TheExaminer
Sep 6, 2015 11:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
