coolant temperature wiring
Old Mar 21, 2008 | 08:32 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Okay i have my stock wiring for the coolant temp. I splice another wire to an aftermarket gauge and the gauge is reading nothing. What could be the issue?
Old Mar 21, 2008 | 08:34 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: coolant temperature wiring
if i'm not mistaken, that sensor runs off of ohm resistance. Does the sensor share a rating (cold or hot) as the new guage you put in? I believe that the box for the guage should have this information for reference.
Old Mar 21, 2008 | 10:34 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
are you trying to run both at the same time? or just the aftermarket one. because if i remember correctly when installing my autometer temp gauge, they would not work simultaneously. you have to wire up just one or the other. also, are you using the aftermarket temp sender?
Old Mar 24, 2008 | 04:00 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Aftermarket gauges usually cannot be used with the stock sensors (different ohm ratings), unless they explicitly mention that.
Also, multiple gauges cannot be connected to a single sensor, then both gauges will show incorrectly. One gauge per sensor.
Hope this helps.
Lou
Old Apr 1, 2008 | 07:30 PM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Anyone got a 'how to' on installing an aftermarket temperature gauge?
Old Apr 25, 2008 | 07:57 PM
edbird4's Avatar
If you are adding an aftermarket temperature guage, you need to drill and tap a hole on the block side of the thermostat or somewhere in the block or head water jacket. Then install the aftermarket sensor and wire it to the aftermarket guage. I have done this and it works well.
eightsixseven
Dec 16, 2024 01:50 PM
Reddeath210
Oct 6, 2015 08:20 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
