fans running all the time .
Old Mar 24, 2008 | 05:32 PM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
i have dual fans that are wired together . they normally come on when the temp guage is about at the half way mark (230 i think) . recently i noticed even when i start my car on a cold morning the fans are already on and never shut off and im afraid it is going to kill my alternator . what tells the computer the car is hot ?
any ideas ? coolant sensor ?
Old Mar 25, 2008 | 02:59 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
Re: fans running all the time .
ok now im seriously confused . both fans were wired into the primary fan relay and were running all the time like i said in the last post , so i wired them into the secondary fan relay and it is doing the same thing ... wtf ????
the only difference is they come on now with the key on , before the car had to be running ...
Old Mar 25, 2008 | 03:28 PM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
theres a fan switch in one of the heads, i belive the passenger side toward the back, check to make sure the wire isnt grounded on something
Old Mar 25, 2008 | 03:34 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
thats only for the secondary fan relay. i have it wired up to the primary fan relay, i believe the temp sensor/ecm controls that .
Old Mar 25, 2008 | 07:18 PM
cusec's Avatar
Car: 1991 RS
Engine: 383 MAF TPI
Transmission: Richmond 6 speed
Axle/Gears: Moser Ford 9 inch
I believe if the AC is on the fans come on. Might try checking that circuit.
Old Mar 26, 2008 | 12:25 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
that is also for the secondary fan circuit . i am wired into the primary .
today i replaced the primary relay and the temp sensor and it is doing the same thing , what is left ? the ecm ?? this was working fine for the past yr till recently , i cant figure out what could have went bad ....
Old Mar 26, 2008 | 02:23 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
turns out 89305formula was correct in checking that switch . i unplugged it and the fans shut off and began to work normally (on at about 225*).
if that switch is bad it will trigger both relays to stay on constantly .
i have a 88 iroc 5.7 tpi with dual fans and both fan relays are by the battery with a blk/red + wire on both for future reference .
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
justin57
Aug 20, 2015 07:05 PM
