Help!
Old Apr 2, 2008 | 03:34 PM
rocco 87's Avatar
Car: 87' Iroc Z-28
Engine: 5.0
Help!
i've already searched the threads and cant seem to find someone with a direct answer. i was running the car and never had the fans turn on. i know they work without the motor running when i read the codes. but when at temp it just keeps goin up
Old Apr 2, 2008 | 04:00 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: Help!
Check your fan switch and the wiring to it. I don`t know if yours is a 1 or 2 wire but they sometimes get burned through and the switch will not work. Sometimes the switch wears out and needs to be replaced. Verify with your shop manual that your fan switch is on the passenger side head and then check it and the wire.
Old Apr 2, 2008 | 10:08 PM
rocco 87's Avatar
Car: 87' Iroc Z-28
Engine: 5.0
Re: Help!
ok thanks alot man.
Old Apr 3, 2008 | 03:53 PM
cusec's Avatar
Car: 1991 RS
Engine: 383 MAF TPI
Transmission: Richmond 6 speed
Axle/Gears: Moser Ford 9 inch
Re: Help!
Also check your fan relays. Also if you turn your A/C on the fan should come on independent of the temperature sensing system.
