Heater hoses above oil filter?
Old Apr 2, 2008 | 08:30 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
I deleted my heater due to the heater core leaking and i also pulled my engine due to a rod knock. but above my oil filter my heater hoses run into it, what is that about???
Old Apr 2, 2008 | 08:54 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Heater hoses above oil filter?
Thats the factory oil cooler!
Old Apr 2, 2008 | 08:59 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Thats what i was thinking it had to be, im just gonna run them hoses to from there to the rad then.
Old Apr 3, 2008 | 02:13 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Factory oil cooler next to useless.
More like an oil warmer in cold climates.
Remove it and all the lines,(Clean up under hood clutter)
and get yourself a (Effective) plate cooler if you want.
Keep all the OEM cooler componets if you want to ever
restore car to original, as was a package option
on our cars.
Later
Old Apr 3, 2008 | 04:57 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
what temps does oil usually run?? So I should just block it all off?? Its useless? Or if i do that then i needed a different kind of cooler?
Old Apr 3, 2008 | 06:51 PM
jaykar's Avatar
Unless your road racing or driving across Death Valley
in the middle of the summer at 140 you wouldn't want
that one. Plus you save a few lbs plus clutter.
( I hate clutter)
I replaced mine with a B&M, stainless lines and anodized
fitting only because we take it to shows. Takes a adapter.
Take it off but save all the steel tubing and cooler if like
I said, you ever want restore to original.
Later
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
carattini
Sep 10, 2015 07:46 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
