Help diagnosing A/C problem
Old May 6, 2008 | 01:07 PM
flyfirebirdfly's Avatar
Car: '91 V6 Firebird
Engine: V6 Chevy 3.1 (modified bore)
'91 V6 3.1 liter Firebird -- having A/C issues.
It was blowing outside air temp (hot today!), hooked it up, gauge was reading slightly low so I topped it off. No change. I don't hear the compressor kicking on at all. I had the same problem with my last car, which I topped off and swapped out the relay with no luck.
Ideas? Thanks!
Old May 6, 2008 | 01:55 PM
tomanahawk's Avatar
Car: 1992 Chev. Camaro (project car)
Engine: 5.0L V8
Re: Help diagnosing A/C problem
ideas, here are a couple, but not a gaurentees.
The compressor might have seized up.
Dont just top of the freon, replace it, particles will like metal shroudings will damage the compressor and clog up the filters that are in the lines
Old May 6, 2008 | 08:58 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
if your compressor is not cycling on then you wont be able to get a proper reading on the gauges. jumper the electrical connector that is located on the receiver/drier, this will force your compressor to cycle on, then get the readings on the gauge. 30-40 low side is were you want it while car is at idle. high side pressure doesn't really matter at this point.
if your compressor does not cycle on when you jumper the connector, more than likely your compressor is bad, check for continuity through all the wires. if it does cycle on, and your readings are correct 30-40 then your low pressure switch is bad, replace it.
GTAman
Mar 15, 2019 11:40 AM
theshackle
Mar 5, 2017 06:37 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
