picket up some volts
Old May 27, 2008 | 09:24 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
I just converted to dual fans on my 85 iroc . When fans are not on my volts read 15.5 at the battery is this ok . Befor with the clutch fan it was in the mid 14teens
Old May 28, 2008 | 11:54 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: picket up some volts
honestly, your volts shouldn't go much past 14.7v. instead of using the dash gauge, hook up a voltmeter to the battery while the car is running just to make sure the gauge is accurate. you don't want the alternator overcharging the battery- it actually will shorten the life of the battery.
...and what fans did you use? i'm thinking about an electric fan conversion on my 83 and looking for opinions.
Old May 28, 2008 | 12:30 PM
Johnx's Avatar
Car: 1990 Iroc
Engine: 383
Transmission: th350
Axle/Gears: 4.10
Like ^ said. Your voltage regulator might be going out and what will happen is the battery will start boiling the acid out. Check the battery and see if you see steam\acid coming from it
Old May 28, 2008 | 09:48 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
It Is 15.2-15.25 whithout the fans on . I did this with a multimeater . My battery is not hot or boiling . I is only like this intill fan one kicks on .Mybe 5 mins. I gess that old clutch fan drew some power .
Punkdude I used some stock fans from a thirdgen with 2 painless relays #30101 and 2 summit thermo switches . 1 comes on at 185 and the other a 200 .This is a non cc-car .I love it and the thirdgen fans install so nice.
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
