AC experts needed.......true or false?
Old May 27, 2008 | 11:01 PM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
I've been told that you do not need to plug in the high pressure cut-off switch in order for the compressor to work.
The reason I ask is because I have a new compressor but it has the wrong switch. I was told that it will work without plugging in the switch in the back. Is this true or false?
Old May 29, 2008 | 01:25 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: AC experts needed.......true or false?
I'm no expert but my impression is that the cutoff needs to be normally closed (connected). Just try it out w/o, it won't harm anything. If it doesn't work then you know you have to short out the plug, exhange it, or make an adapter.
okfoz
Mar 9, 2017 02:35 PM
djmarch
Oct 2, 2015 10:41 PM
ASE doc
Sep 22, 2015 03:13 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
