Dual fans. which fan turns on?
Old Jun 13, 2008 | 08:36 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
ok so i bought TPI parts 200-180* fan switch. it works great keeps the car at a "safer" temperature. but my question is what fan is suposed to turn on? before i installed the switch im almost 100% sure it was the drivers side that turned on. but after i installed the switch the passanger side fan turns on.
i always thought that the passenger side fan only turns on when the ac is on and the drivers fan is the primary.
its a 87 GTA 350 TPI dual fans
Old Jun 13, 2008 | 08:44 PM
Stephen's Avatar
Car: 87 GTA
Re: Dual fans. which fan turns on?
On my 87 GTA....
Passenger side primary...Drivers side secondary.
Old Jun 13, 2008 | 08:48 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
On my 88 Formula, Drivers side Primary and Pass side secondary. Secondary Fan is controlled by the fan switch in the pass side head as well as the A/C Pressure switch.
Old Jun 13, 2008 | 09:16 PM
ok so it seems its different for different cars. so if the fan switch between cylinders 6 and 8 control the secondary. what controls the primary?
Old Jun 13, 2008 | 10:12 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The primary driver's side fan is controlled by the computer, which gets its input from the coolant temp switch in the front of the intake manifold. The passenger side fan is controlled as Zepher said.
And in case someone asks, on a single fan setup, the fan is controlled by the fan switch in the passenger side head. The computer does not control it.
Old Jun 14, 2008 | 11:11 AM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
Are you sure that on a single fan setup that the fan is controlled by the fan switch in the head? I have a 86 TPI with a single fan and I have no fan switch. The wiring diagram shows the fan relay going into the ECM and to the fan itself with no fan switch at all.
Old Jun 14, 2008 | 11:18 AM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
Old Jun 14, 2008 | 11:33 AM
ok now i under stand, so really the only way to make the primary fan come on lower would be to go into the computer and change the temp.
but i guess if i wanted the primary fan to work first again i could just unplug the secondary fan and plug it into the primary and vice versa. assuming the wires reach. thanks for the help guys!!
Old Jun 14, 2008 | 08:41 PM
Kevin91Z's Avatar
I'm mostly familiar with the later 88-92 setups, so if an '87 and earlier setup is different than I described, than I apologize.
Old Jun 16, 2008 | 09:03 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
Yeah the fan on the pre 88 TPI single fan cars are operated by the computer. No worries.
Old Jun 16, 2008 | 09:06 PM
Stephen's Avatar
Car: 87 GTA
My 87 GTA 350/TPI has dual fans & my FSM for it shows dual fans, so it hasn't just been swapped.The dual fans are original.
Old Jun 18, 2008 | 09:45 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
You nailed it. Passenger fan = secondary fan = fan switch or A/C pressure.
Driver fan = primary fan = computer chip.
Hypertech sells their chips to turn the driver fan on early and they sell the fan switches to turn the passenger fan on early.
You'll really like the 200/185 fan switch. Cool enough, but not draining the electrical system running them all the time either. I'd say it's perfect really.
Old Jul 20, 2008 | 06:48 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Originally Posted by Stephen
On my 87 GTA....
hi i have a major problem my car is running funny. it loose power and shakes badly after a few minutes. i have had it a few shops and after 800 dollars same problem, went to a local dealership and they said i had a dead #8 cylinder, its running hot and my fans not comming on any more even with the ac on.
Old Jul 20, 2008 | 08:18 PM
yeah it is nice now to be able to drive and not have to worry about the hot temperetures. and if it does get higher then the "primary fan can come on at its normal temp and save it.
all good: does it give u these issues after u start driving it or right away?
RazorN8
Jan 7, 2022 11:44 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
