Odor/Fumes inside, Help
Old Jun 23, 2008 | 08:37 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
My 91rs 3.1 has new welded exhaust from manifold back, new weather stripp on doors and hatch, and I'm still getting this Oder/fumes inside.It leaves a odd taste in the mouth as well as faint odor(not rotten eggs)
Vent set on warm or cool, does not help.Fan on or off, does not help.
Can anyone tell me where/how fresh air comes from because i dont think im getting any.
I also notice a slight heahach sometimes after 40-50 minute drive.
Also ac not working if that helps.
Old Jun 23, 2008 | 08:48 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Odor/Fumes inside, Help
have you or someone else removed the seal from the rear of the hood ? it seals eng. bay fumes from entering vents at base of windsheild . re-install it and i think your problem will be solved . good luck .
Old Jun 23, 2008 | 08:52 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
I hate to be stupid but is this like a door weather strip.The hood has been changed by previous owner and im not sure what to look for.
Old Jun 23, 2008 | 10:41 PM
UNCLE TOM's Avatar
open hood , look across rear of hood , if it has not been removed you will see it . it should be where the hood rests on top of firewall in front of vents & wipers . good luck .
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
