New Lower Radiator Hose Leaks at Ends
Old Jul 19, 2008 | 04:06 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Well yesterday I was pulling into a parking lot for a informal car show with my 86 Iroc and when I parked and got out all of a sudden I see a huge amount of coolant comming out from under my car. Upon further inspection I saw that the lower radiator hose had sprung a leak at the water pump. Was spraying out of the hose. It was the original hose by the look of it and it bad shape (looks like oil had soaked it for years and it bloated the hose) I replayed it after a quick run to a local parts store. The next day I noticed that there was a puddle under my car agian. The new hose is leaking around where they slide onto the water pump and radiator. I have the clamps in the right position and clamped down tight. yet I can still see coolant on the end of the hose slowly leakin out.
Old Jul 19, 2008 | 04:57 PM
mawinc's Avatar
Re: New Lower Radiator Hose Leaks at Ends
Are they the spring clamps? We dont reuse those most of the time. I have been an auto tech for 23 years. Sometimes the water pump will have a crusty buildup you will need to clean of before putting your hose on.
Old Jul 23, 2008 | 05:36 PM
sorry I haven't posted sooner, my computer went down for a couple days. I use hose clamps. The reason was the clamps were not seated correctly and there was some buildup on the neck of the radiator and water pump. Its fixed now.
Old Jul 23, 2008 | 06:23 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Mine did that and it wasnt my hoses i replaced um when i did the water pump cause right when i told my uncle where it was coming out from he said waterpumps bads so thats prolly it if its same as mine and mine leaked bad too. it was leaking so bad i went throught 2 gals on antifreze in 1 week. Changed pump worked fine no leaks
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
